T@B speaker size and mounting depth
slvrhand
Member Posts: 3
Hello, all:
In a past life I installed car audio, and I have some 6.5" higher-end speakers laying around - has anyone tried to replace the speakers in their T@B?
Much thanks,
Slvrhand
Tampa, FL
Much thanks,
Slvrhand
Tampa, FL
I recall that someone did but can't remeber who as it's been awhile - Have you tried searching "speakers" ?0
I see someone replaced stock speakers with 5.25" Kickers - I've be able to mount 6.5" in similar space as long as there was enough depth. Thanks! (I'll be putting in Polkaudio MM6502's)
Cool, glad you found it.0
Our 2015 Sofitel has plenty of depth.
- Hash T@B Fun
Did you mount the component tweeters? If so where did you mount them. Any update on how the fit? I also have a set of these speakers laying around I though about using.slvrhand said:I see someone replaced stock speakers with 5.25" Kickers - I've be able to mount 6.5" in similar space as long as there was enough depth. Thanks! (I'll be putting in Polkaudio MM6502's)0 -
My mistake - they're MM651's, so they are coaxial, rather than DB6502's.Fatman1966 said:Did you mount the component tweeters? If so where did you mount them. Any update on how the fit? I also have a set of these speakers laying around I though about using.
That said, if I had to get the DB's to fit I'd probably take the existing cabinet fronts off and replace them with these:
http://www.parts-express.com/dayton-audio-mb25-blank-baffle-for-025-cu-ft-cabinet--302-709
and then mount the tweeter in the upper corner by the trailer wall, with the driver moved to accommodate. Crossover goes in the bottom of the cabinet with epoxy, then wool fiber fill.
If you want to get fancy, put a passive radiator on the side aimed across the back...
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
- 54 üCamp Rally - News & Information
