T@B speaker size and mounting depth
Hello, all:
In a past life I installed car audio, and I have some 6.5" higher-end speakers laying around - has anyone tried to replace the speakers in their T@B?
Much thanks,
Slvrhand
Tampa, FL
  • Nomad
    Nomad Posts: 7,209
    I recall that someone did but can't remeber who as it's been awhile - Have you tried searching "speakers" ?
  • I see someone replaced stock speakers with 5.25" Kickers - I've be able to mount 6.5" in similar space as long as there was enough depth.  Thanks!  (I'll be putting in Polkaudio MM6502's)
  • Nomad
    Nomad Posts: 7,209
    Cool, glad you found it.
  • Dalehelman
    Dalehelman Posts: 2,414
    Our 2015 Sofitel has plenty of depth.
    1. Hash  T@B Fun
  • Fatman1966
    Fatman1966 Posts: 149
    Did you mount the component tweeters? If so where did you mount them. Any update on how the fit? I also have a set of these speakers laying around I though about using.
  • slvrhand
    slvrhand Posts: 3
    edited August 2016
    My mistake - they're MM651's, so they are coaxial, rather than DB6502's.
    That said, if I had to get the DB's to fit I'd probably take the existing cabinet fronts off and replace them with these:
    http://www.parts-express.com/dayton-audio-mb25-blank-baffle-for-025-cu-ft-cabinet--302-709
    and then mount the tweeter in the upper corner by the trailer wall, with the driver moved to accommodate.  Crossover goes in the bottom of the cabinet with epoxy, then wool fiber fill.
    If you want to get fancy, put a passive radiator on the side aimed across the back... :)
