No power on battery alone
Second trip on my T@b. I have no power when using battery alone. Battery switch is on. Fuse ok. Checked fuses and breakers on inverter. When connected to shore power meter says battery voltage is 13.2. I appreciate any ideas on how to figure this out.
    So, is your meter blank when not connected to shore power?
    Am I correct in assuming all your 12 volt devices (lights, fan, water pump, etc.) work normally when you are on shore power?
    Did you measure the voltage right at the battery terminals? If so, what was it?
    If your battery voltage says 13.2 when on shore power, it's not your converter. I know you checked the fuses, but sometimes they don't look blown. The inside fuse in the converter should be 30A and the outside in-line fuse in the battery case should be 30A (both large flat blade). I know this is obvious. The less obvious is to check out wires to see if they have loosened up. Please remove the in-line fuse at the battery first! Don't want it to be a shocking experience! Next less obvious is to check in the black box under the T@B near the propane tank and battery bin. Pry it off with a screwdriver, it has a seal and can be stubborn. Make sure there are no loose screws and no bare wires grounding themselves.
    After these things, then it's time to take it to an RV place to get it troubleshooted by a certified electrician.
  • RamrodRamrod Member Posts: 164
    Update. I drove four hours with Norcold on. Left Norcold on for 9 hours and in the morning there was absolutely no power. The battery meter and all lights, etc were blank/not functioning. Drove nine hours and the same. Was on shore power for the night and in the morning when I disconnected it the battery voltage was 13.6 and everything seemed to be functioning well. Drove another 9 hours and when I disconnected the trailer from the TV, once again no power whatsoever. I just connected to shore power and everything is fine. I will go thru above checklist. Thank you.
    Are you running the Norcold on 12 volt DC power? You can only do that when you are connected to a running tow vehicle, and that running tow vehicle has an adequate 12 volt charge line hooked up to the 7-pin wiring harness. Even then, many vehicles struggle to keep up with the power demand, and the battery may still get depleted.
    Where and how are you measuring your "battery voltage?" Keep in mind that if you are plugged into shore power, the voltage you see is reflecting your converter output, not your battery's state of charge.
    I was not aware that I cannot run the Norcold on 12 V battery power while driving. I have to check the TV output (I have to find the discussion that addresses how to do it). 12.6 volts at the battery terminals now and on the wall battery meter after being on shore power about an hour.
    Sounds like we may have found the source of the problem--I'm guessing you may not have that 12 volt charge line (not all vehicles do).
    It does sound like your converter is working properly, everything is connected as it should be, and your battery is taking a charge. If the battery is able to hold the charge is another issue--I learned the hard way that repeated excessive deep cycling compromises the battery. Good luck, and let us know what you discover!
    I had to have a fused wire run from my battery back to the 12v pin on the 7 way connector. You may not have it, or if you do the fuse may have blown.
    I found the culprit. My TV was not charging rhe battery. Fuse is blow. Why?
    Which fuse - on the TV charge line or the one on the T@B battery or the one in the converter box?
    Are all three matched up at 30 amps?
    edited August 2016
    On the TV battery charge line. 2011 Acura MDX. It was a 20 amp fuse.
    Think from other threads that it should match the others - All 30s
    30 on mine both TV and Trailer.
    If I change it to a 30 amp fuse I have read the wiring may overheat.
    What gauge wire do you have? The T@B has 30s, your TV should also or you will probably blow again. If you charge wire can't handle it, you should probably string a new one. But, I'm betting your wire can handle it and you can just plug a 30 in.
    10 gauge wire is necessary for the TV charging plug. I also have 12V outlets directly wired in my truck cap. They are also wired with 10 g (with inline fuse).
    edited August 2016
    Agreed. 10 gauge wire is rated for up to 30 amps. 12 gauge is for up to 20 amps. Ramrod, you are correct that you should not install a larger fuse unless you verify that the wiring is sized to handle it.
    edited August 2016
    It is a factory designed towing wiring for Acura MDX
    Out of curiosity, what does the 12v line from the car battery thru the 7 way plug feed in the T@B, besides the refrigerator? The 3 way fridge on 12v shouldn't draw more than about 14 amps per the manual, and if there's nothing else a 20a fuse would be appropriate.
    @Photomom, it also charges the T@B battery while driving. The T@B battery has a 30A fuse as does the converter for the battery fuse.
    Thanks!
    edited August 2016
    Photomom is correct, the fuses do not all have to match.  The TAB has a 30 amp fuse at the battery but that does not mean you will be drawing 30 amps through your 7-way charge pin.  If you are then you have an awesome battery charger/tow vehicle combo!  I imagine it will be much, much lower than that.  If you run the fridge on 12V while traveling then you might get close to 20 amps.  EDIT - I'm not sure if the fridge draws power direct from the tow vehicle.  More likely it draws from the battery directly, which in turn is charged by the tow vehicle.  That is an assumption, though.
    If I understand it correctly, the 12v line connects to both the battery and the converter via the junction box under the front of the T@B. You might think of it as three spokes with the junction as the hub. That's why it can run DC devices (like the fridge) as well as charge the battery. The DC power supply for the fridge comes via the converter.
    Often the factory wiring doesn't have a high capacity (high ampacity) charge line.
    The 20A fuse that Acura installed is probably the right size for the wire-size they installed.
