If you get a portable car port beware of the danger of collapse if you get heavy snow.dalehelman said:You would need some skirting around the bottom. A way to trap heat. Heat tape on water line. A dependable heat source gas or electric. A cover such as a car port would be good.
Just bring your shovel to dig out your boondocking site! I think you would have to use a generator because of the need to heat tanks. If you are good without the fresh water or tanks, you can definitely do it, I have done it. The Alde is a phenomenal little unit! I brought my own fresh water and used WAG bags. Your ability to recharge with solar will be diminished in the winter, but should still mostly work in CO, where you get all of that sunshine. In PA, it would not work. Nov - March is mostly grey skies. :(Smullis7 said:ColoradoGal, I'm would love an update on this. I'm in CO and would love to go out boondocking in the winter and was wondering what could be done to make this possible. I would love to have the water (fresh, gray and black), but could pretend I'm in a tent again. Will the Aldi, that uses glycol, still work for heat only?
