Towing w/o T@B Battery
2»
    ScottG said:
    What I understand from previous discussions is that the dealer installs the cut-off switch at the battery. Unless they are doing something fancy with the wiring (not likely...), that almost certainly places it on the leg between the battery and the junction box mentioned in my previous post.
    Hopefully someone with a newer T@B can confirm this.
    Yes, that is how ours is wired. We make sure to have the switch on when towing, it's an item on our checklist.
    Mine has the dealer installed cut-off switch.  The brakes are interrupted when you turn the switch off.
