Getting my T@B ready for the Durango get together, I took it into the shop due to the brakes grabbing and squealing. Good thing I did. Even though my unit is only a year old and about 3000-3500 miles on it, I had a bad wheel bearing seal and the bearings needed to be repacked. The brakes were a simple adjustment. I had a boat trailer have a wheel bearing fail and cost a fortune in a new trailer axle. If I was not going to go through a mountainous area, I might have waited for the brakes but good thing I did because the wheel bearing issue was found! Watch out Durango, here I come!
                "Great spirits have always encountered violent opposition from mediocre minds." Albert Einstein
2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ.
2 ·
Since it's new, shouldn't need anything. Mine didn't, did 9k direct from the dealers lot, had bearings greased at 6 on the road.
I would think most mechanics could adjust the brakes and your guy will have the wheels off anyway to do the tires. (Make sure he knows not to put the jack under the axle!)
Brake adjustment info is in T@B owner manual if your mechanic needs it. Our dealer didn't tell us anything about maintaining the trailer.
2016 CS S, 2008 Toyota Tacoma
Somerset, VA
The owner's manual--such as it is--can be downloaded from the T@B home page under the "Customer Resources" link.
From the section on electric brakes: "Elevate the camper by positioning jacks under the frame 12” to 20” behind the axle. Use the jack stands under the frame to support the camper any time it is elevated."
In addition, the component manual that comes with the AL-KO axle says, "Never use the axle or any portion of the suspension to lift or support the trailer."
The dealer didn't give us an owner's manual. I was told I could "Google it." I did download and print it, at which point I found out my expensive Epson printer was lousy even after using a lot of ink going through the maintenance steps. Then on the Sunday before Labor Day, by luck I came across the requirement for a brake adjustment at 200 miles. I drove into the North Georgia Mountains on Labor Day to attain the mileage, and hope I can find someone to do the adjustment today. We head out in the morning to camp and catch a train at the Grand Canyon. The dealer could have saved me a lot of worry by mentioning the brakes and battery maintenance when they sold me the trailer. I hope my local mechanic can do it. I really don't want to drive through our horrible Atlanta traffic to beg our dealer to do the maintenance today, but I will if I have to.
Do any dealers actually do this?
Somerset, VA
It's too bad that a huge corporate chain is setting the bar higher than the small independent dealers. But at least the bar is being set!
