Frig temp digital readout
Dalehelman
Member Posts: 2,414
For about $10
temp gage from Amazon less than $7
on off push button switch from Radio Shack about $2
2 wire conectors
2 wire conectors
- Hash T@B Fun
2
I like!Verna, Columbus, IN
Nice! I like that mod.0
Is there a wire to the sensor or is it wireless?John and Henrietta, Late 2016 T@B S Max in Western New York0
Nice!!!2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0
There are 3 wires on the one I chose because I wanted the read out to light up. One wire is positive 12v one wire goes to a ground the third wire is the probe that goes inside the frig. There are gauges that have there own batteries but the read out is not lighted but they are hard to read unless they are at eye level. The power source is located right behind the gauge. I installed an on off switch so I can turn it off at night.
- Hash T@B Fun
Brilliant. I will be adding one to my T@b2014 T@b S Max AKA T@dpole0
Ok Dale, That cinches it, I'm coming over to check out your mods! Where did you find a Radio Shack local? They closed the one that was up here on my side of town. [Darn it!]2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf0 -
@ericnliz do a search on Amazon for "on/off rocker switch" and take your pick-- plenty to choose from. The two Radio Shacks around here are pretty useless any more. In fact, come to think of it, the small one closed and the only one left is in the mall. The chances of me going into the mall are slim to none
Verna, Just talked to Dale, and I'm going to head his way shortly. ['Gonna pick his brain on some of his mods] I'm personally not a "mall rat" either, so I can totally relate.
You get me out shopping for anything, you've made quite the accomplishment! Drives my dear wife crazy sometimes!
Eric aka: Lone Wolf1 -
Hi @Dalehelman excellent mod thanks. I can't see from the photos - how did you get the probe into the fridge?0
This is what I have. Works well and is a good option if you want to avoid drilling or tapping into the wiring, or adding to the load on the T@B battery. And it shows coldest/warmest temp. http://www.amazon.com/AcuRite-Refrigerator-Freezer-Wireless-Thermometer/dp/B004QJVU78John and Henrietta, Late 2016 T@B S Max in Western New York0
Loosen this screw. Then tuck the probe and wire under the metal strip. I used gorilla tape to secure the wire in the groove under the shelf. Any small on off switch will work. I already had a small push button switch on hand.
- Hash T@B Fun
@Photomom - I see it comes with two sensors, do you find that you use both or just one? And does it have the ability to turn off display or does it display all the time? Thanks!Photomom said:This is what I have. Works well and is a good option if you want to avoid drilling or tapping into the wiring, or adding to the load on the T@B battery. And it shows coldest/warmest temp. http://www.amazon.com/AcuRite-Refrigerator-Freezer-Wireless-Thermometer/dp/B004QJVU782013 MAXX T@B towed by a 2015 Volvo S60 5 CYL AWD Sedan
Seattle, WA -> Palm Springs, CA0 -
It displays all the time but is not backlit so it's not obnoxious.
I use one sensor in the fridge and one in the T@B cabin. Was not able to find a similar device with only one sensor.John and Henrietta, Late 2016 T@B S Max in Western New York0 -
I have the wireless sensor (use only one) and it works well. Backlit is very unobtrusive.0
I put the 2nd sensor in the propane/battery tub and it give me the outside temp. While I do have the diamond plate tub, it does reflect the excessive heat away and gives me an accurate temp, I do not know if the plastic tubs will give the same result.Verna, Columbus, IN
- 424 Service/Maintenance & Recall Notices
