We just bought a 2013 T@B S yesterday, it came with the yellow "shore power" cord under the seat by the door,
In my previous RVs there was an outside compartment door that I stored the white water hose, a floor mat, wheel chicks, etc.
The dump hose fit into the 4" rear bumper.
I read the manual & forums, but did not find an answer: where do you store your hook up hoses? I don't want it inside, I guess I could put it in the battery/propane front compartment?
Can you share best practices?
Walter
2013 T@B S
Tesla S tow vehicle
Austin, TX
0 ·
2014 T@B S M@xx with wetbath, aka PopT@B, silver with black trim, TV 2002 Chevy Avalanche
"Take only pictures, leave only footprints."
I also store the dump hose into he propane box. I have a clear elbow attached to mine that I stick into he PVC pipe and the rest just sits on top of everything else. I have a bungee to hold it in place, but I am not sure that is necessary. I keep the water hose for potable water in one clear Rubbermaid container and the one I use for rinsing the dump tanks in another clear Rubbermaid container. Those 2 containers either go in my Jeep or on the floor of the T@b, depending on my next destination and my how much I will be hooking up. I am still sort of sorting some of this out. I might end up putting it in the T@b where Debbie described.
Debbie, I like the idea of storing the gloves in a baggie in the PVC pipe and might do that, too. I use electrical cord storage reels to keep my hoses neat. You can only put about a 25' hose on a reel or else the reel will loose its shape. I have been pretty happy with the reel method.
I use the a clear elbow (where it goes into dump connection) and that fits perfectly into he pipe without going all of the way down in..The hose then just sits on top of that, battery, and propane.
Jeff
Freshwater hoses, my collapsible grey water jug, and my stabilizer crank go in the drivers's side hatch.
I mounted a 6' long large PVC pipe with screw on ends onto the front frame, just behind the propane tank for my grey water drain hose for when I have full hookups.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
I currently keep my sewer hose in one of the action packers (mounted exactly like yours), but it would be nice to use that space for other things.
