Need more space replumb "P" trap under sink
Dalehelman
Since every inch of space is precious in our T@Bs I managed to squeeze a little more from under the sink. It may not look like much, but it made the space a lot more useable. It required two 60 degree 1 1/2 abs pipe fittings. First picture is after. Second picture is after. The plastic bin would not fit before..
- Hash T@B Fun
Can't do this one as my water heater is in the way, but this is a nice, simple change that opens up some space.
Sterling, VA0 -
Nice mod. I worked around it by stacking my frying pans so the dip dips into the center of the pans.0
Looks good! Did you cut the down pipe (highly technical plumbing term
) Or did you slide the P trap upwards to fit the new drain path? Mark - 2016 T@b Max S (Silver/Red), 2012 F-1500 -
PXL, how did you manage to get in the fry pan?
Eric aka: Lone Wolf0 -
I cut the tail piece shorter to raise the "P" trap. Then I cut and left about a 1/2" at the "T" on the vent/drain pipe. I also rotated the the "P" to the back.marknjudy said:Looks good! Did you cut the down pipe (highly technical plumbing term
) Or did you slide the P trap upwards to fit the new drain path? - Hash T@B Fun
Excellent! This will be my next project.Mark - 2016 T@b Max S (Silver/Red), 2012 F-1500
Interesting and does not look to difficult to do. Any concerns about draining OK? I am no plumbing expert.
It's all about gravity. Mainly I raised "P" trap for more clearance under it and rotated it to the back of the cabinet.
- Hash T@B Fun
- 144 Events & News
- 415 Service/Maintenance & Recall Notices
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
