Need more space replumb "P" trap under sink
Dalehelman
edited September 2016 in Modifications & Upgrades
Since every inch of space is precious in our T@Bs I managed to squeeze a little more from under the sink. It may not look like much, but it made the space a lot more useable. It required two 60 degree 1 1/2 abs pipe fittings. First picture is after. Second picture is after. The plastic bin would not fit before.
  1. Hash  T@B Fun
  • Cyclonic
    Cyclonic Member Posts: 1,232
    Can't do this one as my water heater is in the way, but this is a nice, simple change that opens up some space.
    Sterling, VA
  • Nomad
    Nomad Member Posts: 7,209
    Nice mod. I worked around it by stacking my frying pans so the dip dips into the center of the pans.
  • marknjudy
    marknjudy Member Posts: 378
    Looks good! Did you cut the down pipe (highly technical plumbing term :) ) Or did you slide the P trap upwards to fit the new drain path?
  • ericnliz
    ericnliz Member Posts: 4,437
    PXL, how did you manage to get in the fry pan? =)
  • Dalehelman
    I cut the tail piece shorter to raise the "P" trap. Then I cut and left about a 1/2" at the "T" on the vent/drain pipe. I also rotated the the "P" to the back.
    1. Hash  T@B Fun
  • marknjudy
    Excellent! This will be my next project.
  • jkjenn
    jkjenn Member Posts: 6,425
    Interesting and does not look to difficult to do. Any concerns about draining OK? I am no plumbing expert.
  • Dalehelman
    It's all about gravity. Mainly I raised "P" trap for more clearance under it and rotated it to the back of the cabinet.
    1. Hash  T@B Fun
