This is my second season with my '15 T@B CS-S. Turned the Alde on last night and no heat. I am driveway camping and plugged into shore power. Water tank is empty. LP is on. Controls are one lightning bolt,, LP flame, column three is "0", and temp set a "0". Nothing. I checked the fuses on the converter and the "hidden" fuses under the seat. Still nothing. I've spent the better part of the day going through the forums and manuals and still nothing. Any suggestions? Please! I'm hoping to get some more camping in this fall, and could probably use the heat. Note: it worked fine last year. Don't know it this has anything to do o do with it, but the converter's fan runs constantly, but I'm assuming that is because I have no battery.
martha in Vermont '15 T@B CS-S Max H@ppy C@mper
0 ·
However, you also have to turn the Alde on. "Column 3" allows you to select heat and hot water, or just hot water. The "0" setting is off.
J.D. & Sue
2018 Chevy Colorado V-6
Edmond, OK
Edmond, OK
If the "hot water only" setting indeed works fine, I would suspect a snafu in the "cabin heat" circuitry rather than with burner itself. That's just a guess, though...
martha in vermont
