Hi All,
I'll be driving over mountains and through snow this late fall to visit my sophomore daughter at Oregon State U.  I did it last November with no problem, but all that we experienced were a few snow flakes.  This year might be different.
Questions: Has anyone driven through mountainous areas requiring snow chains towing a t@b?  We have a Subaru Outback with all wheel drive so I'm not concerned about my tow vehicle, but not sure how the t@b will manage.   Additionally, will the highway patrol let me go through chain control areas?
                1 ·
No? I may be wrong about that.
We pulled the Tab through heavy snow in (flat) southern Ontario. Didn't have a problem, but did wish we'd put snow tires on the Tab, just as a precaution. I think it'd be more likely to track better and brake better in slippery situations with snow tires.
In-town with slight (or no hills) is manageable, but down steep snowy mountain passes is another thing. It's very easy for the T@b to get ahead of you especially if your vehicle has chains. Before you know it you'll be sideways with the T@b swinging in front of you!
One idea is you could put chains on the T@b too (outback models only I'd say), and keep a hand on your brake controller to let the T@b do your braking down the hills.
I personally wouldn't risk it in any case, unless the roads were just slushy. YMMV.
2014 T@B CS Maxx
Martha Lake, WA
Hit some soupy sand on a gravel road once that acted just like snow/ice. The T@B was jackknifed at 30 degrees before I managed to get into 4-wheel, gun it and straighten everything out. Wasn't a good feeling to see the T@B sideways in my mirror.
If I anticipate a lot of snow, I take the Xterra, which I do have chains for. Haven't towed the T@B in the snow yet, but I imagine I will at some point. If the roads get too bad, I'll stop and camp.
2022 Ford F350 Tremor | 2022 Cirrus 620
I think the reason Subaru doesn't recommend chains on their car has to do with permanent all wheel drive. If you only chain the fronts for example it causes imbalances in the tire speeds and can cause excessive wear or damage to the drivetrain. Chained tires spin slower. It may also have to do with limited clearance around the tires. I'd like to hear Subaru's official reason for it.
2014 T@B CS Maxx
Martha Lake, WA
