XL Visor pole
So I set this up for the first time in our driveway. I found that the sleeves on the fiberglass poles hang up badly while inserting into the pocket. Same thing getting them out. Anyone have some insider tips to making this process easier?
2017 T@B Max S, 2016 Jeep Wrangler Unlimited, Birmingham, Al
  • Ratkity
    Ratkity Member Posts: 3,770
    Push the poles in, don't pull. So that means the first pole that is inserted is the one with the sleeve on it, so the next pole fits into it. To get the poles out. Unpocket the end pole from the entry point, go to the other side and slowly push the poles through the sleeve - never force the poles through the sleeve. Be careful and try not to pull on the bungie. Hope that helps!
  • Michigan_Mike
    Best thing you can do is to bunch the material up on the receiving end, push it through as far as you can and repeat the process until you get the tip of the fiberglass pole to the opposite end.  That's about all you can do and exercise some patience too as it does get easier with use.   ;)
  • Cyclonic
    Cyclonic Member Posts: 1,232
    Yup, what Mike said, just takes some patience and practice.  Not really any different then any tent I have ever had.
    Sterling, VA
  • Tabaz
    Tabaz Member Posts: 2,421
    Your shock cord may be too long.  Simply remove one the rubber ends and take out some slack. Don't take out so much that you can't fold the pole sections comfortably.
