I was wondering....
  could one use the Alde heater to keep things warm enough inside the T@B [on shore power] to alleviate the need to winterize? If cupboards, shower door, and side bench panels were left open/off to allow heat to get in these areas would it keep it warm enough to stave off freezing temperatures enough for the pipes/tanks not to freeze? This is more of a curiosity question than anything else, just looking for some input from others on this. Thanks.
0 ·
An odd curiosity :-)
I do admit that I kept the Alde on for a week or so at 55* after I came back from AZ in April. I had to go out at midnight one night to winterize and I was a bit worried. I did leave the shower door open so the air could circulate. Everything was OK, so the super quick blowout with the manual bike pump and the pink antifreeze in the traps worked.
However, my impression is that RV components are probably not robust enough to withstand 24/7 operation. I'd end up spending more time checking up on the T@B then I would have spent just winterizing it in the first place!
http://www.campingworld.com/shopping/item/tank-blanket-20-gallon-ac/71648
