A/C box
Plexiglas is acrylic, and IMHO a plastic with better impact properties would be a better choice like ABS or polycarbonate (Lexan). If the wood rots, I'd probably go with ABS for next version, easy to find it in black.
Seattle, WA -> Palm Springs, CA -
Thanks, would the ABS/ Lexan be easier to drill through for the mounting holes? I know from past experience with Plexiglas, it has a tendency to crack & split, especially when you try to tighten it down, and the surface is not real even.2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf -
Here's the paint that matches the T@B the best if you want to paint it...
HEY PXL! Did you paint the other white covers as well? Really looks better the same color to match the rest of the trailer.2016 T@B MAX S-aka: WolfT@B
Just the vents. Small things didn't bother me or look mismatched...
@ericnliz Yes, exactly. Acrylic is very brittle, harder, it's good for replacing glass, or a plastic that you need to see through, as it has good optic properties, but in terms of impact, it's poor. ABS or Lexan (polycarbonate) is very easy to work with, drill through, etc. It's softer and tougher. For example, when I used to work on cellphones, we would use acrylic for the lenses (that you had to read displays through) but always used lexan for the housings, because it's tough and can take a beating.ericnliz said:Thanks, would the ABS/ Lexan be easier to drill through for the mounting holes? I know from past experience with Plexiglas, it has a tendency to crack & split, especially when you try to tighten it down, and the surface is not real even.
Here's a video comparing lexan to acrylic:
https://youtu.be/Hsls5ZPCUnE
But for a cover, Lexan is overkill, so I'd say black ABS would be a good choice.
Thanks for the insight, much appreciated, I see a mod coming!
- 916 Introductions
- 72 Teardrop Groups & Links
