Cleaning the Blinds
Nomad
Member Posts: 7,209
Has anyone figured out a way to clean the blinds - cleaner/method? They're so flexible :-)
Was thinking of filling the window behind with a folded up blanket or something.
Chloride wipes don't work for squashed bugs on the blinds. That was all I tried yesterday.Verna, Columbus, IN
Tried the folded up towel between the window and blind and they are still a bugger to try to clead :-(
Any suggestions?0 -
Q-tips and alcohol from the outside with the window up? Or maybe get a foam brush with alcohol--that would cover more area quicker.Verna, Columbus, IN
Both sides actually need it - The problem is they're so flimsy it's hard to get and scrubbing action or pressure on them.0
Drive real fast with the windows up and the blinds down???:)
2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 6200 -
Tried that first :-)1
Two people with foam brushes on each sidePXLated said:Both sides actually need it - The problem is they're so flimsy it's hard to get and scrubbing action or pressure on them.Verna, Columbus, IN
Only got one -> When ya showing up Verna? :-)0
What about some kind of pump sprayer thingy, like the ones Verna and Jenn use for dishes. You could spray them from the inside, pushing them off that way? Other more drastic option is to buy a new T@B...:-)2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1
I have successfully used them on bugs - it must depend on the type of bug.Verna said:Chloride wipes don't work for squashed bugs on the blinds. That was all I tried yesterday.
PXL, You could always find a Southwest bug collector to help 'ya. I'm sure you have every kind, form & fashion by now.
Eric aka: Lone Wolf1
