Last week it was fine, this week it's not.
I'm getting no indication that it's even turning on -- I don't hear the water circulating through the coils at the back of the tab, or the gentle water movement sounds beneath the bench.  Also, nothing happens when I turn on the propane assist.  So I'm pretty sure it's not turning on.
I checked the fuses in the fuse box under the bench seat, and they all seem to be intact.  Any ideas?
                0 ·
Look at this thread:
http://tab-rv.vanillaforums.com/discussion/3512/fuses-for-newbies
One thing you might do when you are done using the Alde is to turn it off completely after use. I learned this the hard way and had forgotten to manually turn the unit off, had left it on an after plugging in the trailer and flipping the breakers on the surge of voltage blew out one of the small fuses inside the top cover of the Alde unit. They are very thin and are a quick trip style fuse and susceptible to such an event as well as differences in voltage. An event such as lights going on and off during a storm is also a means of these fuses failing and I've had it happen while plugged into my 30 amp service on the side of my garage.
I did buy a digital thermostat for my trailer, installed it and find it to be easier to operate and also find that the temperature variation is spot on and you can easily control all operating aspects of the Alde this way. I'm also able to easily turn it on and off and do like the touch style thermostat.
M_M where did you get your digital thermostat?
Additionally you also will need to replace the existing analog control wire that runs down inside the wall and over to the Alde unit with a new control wire that comes with the digital thermostat. The new control wire basically just plugs into the existing terminals on the top of the Alde unit after the old wiring is removed. I did leave the old control wiring in place for a while to ensure things worked out, but cut the wiring out later on as it will not be needed.
I did it and it's not a difficult task, but you will need to fish the new wiring down through the wall, into the bench area (I have a T@B Max S) where the electric converter sits and up into the Alde area.
Thanks for the info on the fuses. They looked good but I replaced them anyway, and it's still not working
I'll keep searching for a solution.
Since you know you are getting power at the Alde's 120V receptacle, you should next check the 12V side. Are other 12V devices working (e.g., lights, fan, water pump)? If not, that points to a general problem with your converter. If so, check the specific circuit supplying the Alde.
Even if you are running on shore power, the Alde's electronics still require 12V from the converter to operate properly.
On my Alde unit it says they are both 3.15amp
I have to say that I'm unfamiliar with these slow-blow fuses. Apart from rare cases, it should be fairly obvious when the fuse is blown, no? Like that metal strip would be broken?
Certainly I'd be willing to try a 3.75 fuse on the right side...anything to get it working again! I didn't check the old fuse I pulled out before I threw it away -- can anyone else corroborate that they have two 3.15amp fuses, and not a 3.15 and a 3.75?
However, I did miss-read it once, thinking it said 3.75...
Both of my fuses are identical 3.15 amp fuses.
High power-demand 120V appliances like the Alde, A/C, and fridge have their own dedicated receptacle on their own circuits with their own circuit breakers. While these receptacles could have their own GFI protection, they typically don't
So, while it won't hurt anything to poke at the buttons on the GFI receptacle, unfortunately it will not provide an easy fix to your Alde woes.
