A/C drain hole location 2014 T@b S
Swat
Member Posts: 3
On my 2014 S model the A/C drain hose comes out behind the driver's side wheel. Does anyone know where in the drain pan the drain hole is located. Front, back, driver's side, curb side? Thanks. Dave S.
Front driver's side in a little channel off the pan towards the bath area (if you have one).2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0
If you have the bath, you can remove the mirror and look inside the wall and/or the access panel on the outside of the shower wall and probably see it as well - At least on mine you can.0
Check out "how to remove the air conditioner" for some photos of the drain.2016 Outback 320
2024 Ford F150 Supercrew short bed.0
