A/C drain hole location 2014 T@b S
On my 2014 S model the A/C drain hose comes out behind the driver's side wheel. Does anyone know where in the drain pan the drain hole is located. Front, back, driver's side, curb side? Thanks. Dave S.
  • Ratkity
    Ratkity Member Posts: 3,770
    Front driver's side in a little channel off the pan towards the bath area (if you have one).
  • Nomad
    Nomad Member Posts: 7,209
    If you have the bath, you can remove the mirror and look inside the wall and/or the access panel on the outside of the shower wall and probably see it as well - At least on mine you can.
  • Tabaz
    Tabaz Member Posts: 2,420
    Check out "how to remove the air conditioner" for some photos of the drain.
    2016 Outback 320
