I just finished winterizing for my second time, and I'm still seeing water inside a clear small diameter tube that feeds into the fresh water tank. Does anyone know how to get this water out or does it not matter? I couldn't really get under there to take a photo. I used the blow out method first, then I put 2 gallons of antifreeze in the fresh water holding tank and ran the water pump to distribute it through the system, but this clear line isn't being affected at all. Any thoughts on how to clear this, or is it ok to just ignore it? Thanks
0 ·
I doubt a little water in there will hurt anything, but if it makes you feel better use your lungs and a bit of tubing (or an air compressor) to blow a few good puffs into that hole in order to clear the line back into the tank.
