Brake wires being cut into
I have about 4,500 miles on my CS & found the brake wires on both sides being chaffed badly right where they come out of the frame going to the brakes. I think the frame is cut during manufacturing with a die press & it leaves the edge sharp. The edges of the frames are quite sharp there. I am going to lube my bearings and at that time I will put some spy-rail nylon wire protector around that area of the wires.  You might want to check yours. Art
2019 TaB 320 S Boondock Edge
