Water draining from small tube under rear of T@B.
I just purchased my 2014 clamshell T@B.  Decided to check the heating system.  Propane was on, but T@B was not plugged into house AC power.  Water in holding tank.  Ran the heater for a short time and the T@B got very toasty.  Once I shut off the heater, I noticed water draining from a a small vertical drain at rear of T@B underneath.  Is this normal or is there a valve that should be closed?
