Pictures of some of my favorite mods
Dalehelman
Member Posts: 2,414
- Hash T@B Fun
2
How did you attach the baskets to the door?John and Henrietta, Late 2016 T@B S Max in Western New York1
Love the "tent" dome. Where did you get it from?
Also a description of how you did some of the mods would be very helpful.
2 -
Baskets were attached with 3M red backed double stick tape and 2 screws at the top.
Lesley_and_Ian said:
Colman Point Loma dome from Amazon last price was $175Love the "tent" dome. Where did you get it from?
for more information on other mods please specify which ones.- Hash T@B Fun
Dale, these are great mods. Inspiration for winter projects.
I might have to move our paper towel from 'over the sink' to 'under the sink'. Seems way more sensible there. (Then I'd need to fill the darn holes though)
Thanks for posting.
Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya1 -
Is that a 12' or 15' dome?
Did you have to do anything to raise the feet?2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow)0 -
Delete
- Hash T@B Fun
2 -
Thanks for the info on the dome. Looks great and a good price.
Can you comment on the 2 cargo racks attached to the front? That looks like a great idea.
ATV cargo rack from Harbor Freight about $50. Cutting and welding was required. Then it was bolted to the tongue. Drilling also required.
- Hash T@B Fun
OK thanks, i am out cannot weld!!0
There are people that can weld it for you.Lesley_and_Ian said:OK thanks, i am out cannot weld!!- Hash T@B Fun
I like that tongue rack idea too.. Also can't weld... Maybe another similar rack would only have to be bolted on... Then of course there is the tongue weight issue.. Is that the Outback that has that look? Well, all winter to dwell on it...Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI0 -
Nice!!!Kennesaw, Georgia
2016 Silver/Black T@B M@x S with Scuba Black interior. 2015 Lincoln MKC AWD 2.0L Ecoboost tow vehicle. Tekonsha Prodigy wireless Brake Controller.0 -
Pretty cool mods Dale, thanks for sharing! You DA man!Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0
Thanks Mike always looking for the next idea or challenge. This little trailer had been a wealth of fun.Michigan_Mike said:Pretty cool mods Dale, thanks for sharing! You DA man!- Hash T@B Fun
Yup.. I'd take it on our next trip to the U.K. Or perhaps Paris France, but they haven't finished the bridge.... grinTerry & Jody... 2025 Honda Ridgeline RTL
T@bbey Road
Appleton, WI1 -
Quick question, I see a lot of people storing the black/grey water hose in a tube in the back, how are you attaching that? And is there drilling required?1
It is through bolted. Drilling is required
- Hash T@B Fun
So, I've been following with interest the modifications and upgrades that have been reported on this forum and have incorporated several (bed slats, tv mount used for swing away table) and have recently completed a set of cabinets for our T@B Max S. These mount above the existing cabinets in the rear.
7 -
An additional photo-before adding the doors.
5 -
Very nice
- Hash T@B Fun
You obviously built them yourself correct? Please explain how they are attached.
- Hash T@B Fun
Nice job, and same question as Dale. Could you also give the dimensions please?2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf0 -
I removed the two vertical maple pieces from the rear of the existing shelves above the windows on each side. They were screwed into the wall with two pocket screws on each side. I drilled pockets in the new shelving face frame to match the existing screws and also screwed the frame into the existing above-window shelves. The bottom of the new cabinet is 3/4" maple plywood. I drilled for five pocket screws and then screwed that into the top of the face frame of the existing rear cabinet. The new face frame is attached to the new cabinet bottom by five screws. Those screws run directly through the face frame into the 3/4" maple plywood. Those holes were filled. I then ran a bead of clear caulk between the top of the new face frame and the roof, attached the doors (the hinges are on the top so the doors swing up) and was finished.
So, if I read your directions correctly, you used the caulk between the top of the new face and the ceiling as an adhesive as well as a sealer?2016 T@B MAX S-aka: WolfT@B
Eric aka: Lone Wolf1 -
More as a sealer than an adhesive. It was really well fixed without the clear caulk.
Another feature we added: a pull out drawer beneath the bed slats. We keep the slats in place and do not use the fold up table the trailer came with. We made a 23"W x 32"L drawer with 24" soft close slides to keep our food (in bins). It pulls out 24" which is the width of the aisle in front of the kitchen counter. The soft close holds the drawer in place while traveling.
2 -
@dlud How deep is the cabinet and how high are the openings? Do you plan to use this for additional clothing storage or did you have something else in mind?2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle.0
I love your idea to utilize the space above the rear cabinets. A wood structure was a little more involved and trying to match the wood would be difficult. So in order to take advantage of the space I went with a removable light weight wire shelf. I think I will also add a cargo net. Thanks for the inspiration.
- Hash T@B Fun
Man, don't ya hit your head on those cabinets/shelves when kickin back on the bench seat? I sure would and I'm short.0
PXLated said:Man, don't ya hit your head on those cabinets/shelves when kickin back on the bench seat? I sure would and I'm short.
Surprisingly no.- Hash T@B Fun
