Greetings from a thrilled new T@B owner!
By panels, are you refering to the trim pieces?
I would not remove them. Plastic tends to brittle with age and may break easily. I would mask carefully and spray in place after a light sanding and wipe down with mineral spirits. I have found this product to work well on plastic. I would do a small test befor committing to the complete job.
- Hash T@B Fun
That paint has worked well for me and that color matches my trim.
I had several mods done by a local RV company in Phoenix. Here's my 2-6 volt installation.
Cindy with my 2015 MaxS (Puppy) and my 2015 Subaru Outback (Boo) -
Cindy - Is that inside the standard tub? Did they have to redo the framing? If you don't mind sharing, what did it cost ya?
Great question about the paint. I am considering painting some of my plastic pieces that are discolored with age. I agree about not removing most of the trim, could be a real can of worms! Leslie and Ian, you will love your "vintage" t@b!
Jenn - Yes, just slightly - I have the silver on silver but the trim is slightly darker and it matches that.
There are a couple other Krylon grays in the Walmart selection that are lighter - One of those may match if that's what you're looking for.
Thanks.... just be a little closer sine I have a different color trim. That looks nice!PXLated said:Jenn - Yes, just slightly - I have the silver on silver but the trim is slightly darker and it matches that.
- 953 Air Conditioning & Refrigeration
- 919 Introductions
- 407 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
