Cleared water out. Poured 4 gallons of antifreeze into fresh tank. I set valves as pictured in winterizing pictures, turned on pump (which makes a LOT of noise) but very little antifreeze trickled out for cold water and none for hot. Tried different valve configuratiins. Nothing. Do I have a broken pump? Help, please.
B@t T@b, the 2016 Max S Outback, pulled by Bane, the 2014 Honda Ridgeline.
0 ·
I own a 2015 T@B MAX. Winterizing procedure by little guy was the following. Open all valves to drain water. Company e-mailed me positions of valves for winterization. Using compressor, connect to fresh water inlet, connecter is $8.00, and blow out remaining water. Pour small amount in all drains. 2-3 or more into fresh water tank and down into toilet.
TV is a 2007 Jeep Liberty. Own 2015 T@B Maxx s/wet-bath white green. St. Clair Shores, MI.
BTW, drove by on Saturday and they had a dozen T@B's on the lot, great place to go if you want to see every model. They also have one for rent.
Sterling, VA
