Couldn't get antifreeze to pump thru - need help
Redufresne
Member Posts: 100
Cleared water out. Poured 4 gallons of antifreeze into fresh tank. I set valves as pictured in winterizing pictures, turned on pump (which makes a LOT of noise) but very little antifreeze trickled out for cold water and none for hot. Tried different valve configuratiins. Nothing. Do I have a broken pump? Help, please.
B@t T@b, the 2016 Max S Outback, pulled by Bane, the 2014 Honda Ridgeline.
If I recall correctly, someone mentioned this before and it turned out they needed to fill the fresh water tank fuller.0
Pxlated, i read that, too, but we have four gallons in. Doesn't seem logical to need more than that.B@t T@b, the 2016 Max S Outback, pulled by Bane, the 2014 Honda Ridgeline.0
Sounds like a pump priming issue. I think this is the thread PXL is referring to: http://tab-rv.vanillaforums.com/discussion/3817/pump-wont-pump-antifreeze
I own a 2015 T@B MAX. Winterizing procedure by little guy was the following. Open all valves to drain water. Company e-mailed me positions of valves for winterization. Using compressor, connect to fresh water inlet, connecter is $8.00, and blow out remaining water. Pour small amount in all drains. 2-3 or more into fresh water tank and down into toilet.
TV is a 2007 Jeep Liberty. Own 2015 T@B Maxx s/wet-bath white green. St. Clair Shores, MI.
Thank you. We are going to bring to Beckley's and have them blow out lines and drain tanks etc.B@t T@b, the 2016 Max S Outback, pulled by Bane, the 2014 Honda Ridgeline.1
Beckley's will likely do the winterize with RV antifreeze in the lines. That is fine, and if you have an issue with the water pump they will be able to detect and fix it.
BTW, drove by on Saturday and they had a dozen T@B's on the lot, great place to go if you want to see every model. They also have one for rent.
Sterling, VA1
- 424 Service/Maintenance & Recall Notices
