Couldn't get antifreeze to pump thru - need help
Cleared water out.  Poured 4 gallons of antifreeze into fresh tank.  I set valves as pictured in winterizing pictures, turned on pump (which makes a LOT of noise) but very little antifreeze trickled out for cold water and none for hot.  Tried different valve configuratiins.  Nothing.  Do I have a broken pump? Help, please.
B@t T@b, the 2016 Max S Outback, pulled by Bane, the 2014 Honda Ridgeline.
  • Nomad
    Nomad Member Posts: 7,209
    If I recall correctly, someone mentioned this before and it turned out they needed to fill the fresh water tank fuller.
  • Redufresne
    Redufresne Member Posts: 100
    Pxlated, i read that, too, but we have four gallons in.  Doesn't seem logical to need more than that.
    ScottG Administrator Posts: 5,691
    Sounds like a pump priming issue. I think this is the thread PXL is referring to: http://tab-rv.vanillaforums.com/discussion/3817/pump-wont-pump-antifreeze
  • deputydog
    deputydog Member Posts: 103
    I own a 2015 T@B MAX.   Winterizing procedure by little guy was the following.   Open all valves to drain water. Company e-mailed me positions of valves for winterization.     Using compressor, connect to fresh  water inlet, connecter  is $8.00, and blow out remaining  water.   Pour small amount in all drains.  2-3 or more into fresh water tank and down into toilet.
    TV is a 2007 Jeep Liberty. Own 2015 T@B Maxx s/wet-bath white green. St. Clair Shores, MI.
  • deputydog
    That's it.   No pumping of anti freeze thru system
  • Redufresne
    Thank you.  We are going to bring to Beckley's and have them blow out lines and drain tanks etc.
  • Cyclonic
    Cyclonic Member Posts: 1,232
    Beckley's will likely do the winterize with RV antifreeze in the lines.  That is fine, and if you have an issue with the water pump they will be able to detect and fix it.
    BTW, drove by on Saturday and they had a dozen T@B's on the lot, great place to go if you want to see every model.  They also have one for rent.
    Sterling, VA
