sign in trouble
leroybort
Member Posts: 61
Anyone else having trouble signing in using safari? Firefox works with the same log in info, but lately, safari doesn't. Any tips?
Sug@rsh@ck - 2016 Max S Outback, 2016 Nissan Pathfinder.
I recall in the past there being issues with Safari and the software used here. My suggestion, stick with Firefox.
Sterling, VA0 -
I'm having no trouble on safari0
I'm using an iPad and it uses Safari. Maybe clear cache and cookies and make sure you're using the right login credentials.2013 MAXX T@B towed by a 2015 Volvo S60 5 CYL AWD Sedan
Seattle, WA -> Palm Springs, CA0 -
No safari problem here on any of my three devices - yep, clear cache/cookies and restart safari0
No problems here on Safari. Apparently last night there were probably updates made to the forum software because I had to log into each forum, but that happens every week or so.Verna, Columbus, IN
Safari is really strict on login cookies if you run the default preferences. Go to: Safari Menu -> Preferences. Click the Privacy Icon. Check the Always allow radio button under 'Cookies and website data'. You will be able to login after doing that.
Jon & Angela | Florissant Colorado | 2017 Outback S1 -
Good information and thanks for taking the time to share it John!Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ1
For Safari on iPhone/iPads ... Either of the last two coices are fine...Suspect same on desktop...
When my ipad is slow to load, I end up Clearing History and Website Data on Safari. It works, but of course I then need to login again...Pxlated, I used your recommended Crop Size app for this!
Good boy :-)0
Girl!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Ooooops - And I knew that from your sig :-(0
PXL, At this point, just HOW muddy are your feet anyway?
Jump over those puddles! I will have to admit, it IS entertaining though!
Eric aka: Lone Wolf1 -
PXLated- speaking of signatures - should I be able to view signatures using an ipad/iphone?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
I can see your signature, Sharon, on my iPhone. Watching a BB game on the iPad right now so I can't speak for the iPad right now...SAM said:PXLated- speaking of signatures - should I be able to view signatures using an ipad/iphone?Verna, Columbus, IN
Wether you can see sigs or not depends on how you have it set in your profile - Click on your name at top, then edit profile - it's a drop-down under that little profile graphic. There will then be a list of things like signature in the right hand column you can choose/edit.
OK, I can't see anybody's signatures. My signature profile has "Hide signatures always" checked and you can see mine??? This is on the PC and ipad - what's up with that?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Hide sigs means sigs won't display "for you" not that we can't see yours. Uncheck that and you'll see sigs.0
Well watta ya know! Gotta change that sig!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
I use Safari and frequently have trouble logging into this forum, probably after updates. I found that I can log onto the Little Guy forum, then I'm back in business here.Gil Butler, Folsom, CA, 2015 T@B M@XX CS - White with Yellow tim0
gilbutler - That's kind of strange. Safari has only caused me problems a couple of times. I do keep everything updated.0
PXLated said:For Safari on iPhone/iPads ... Either of the last two coices are fine...Suspect same on desktop...
Correct, both of the bottom options are essentially the same. I use 'always allow' as it is no less secure than the option above it yet has fewest problems with cross URL cookies.Jon & Angela | Florissant Colorado | 2017 Outback S0
- 956 Air Conditioning & Refrigeration
- 921 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
