sign in trouble
Anyone else having trouble signing in using safari?  Firefox works with the same log in info, but lately, safari doesn't.  Any tips?
Sug@rsh@ck -  2016 Max S Outback, 2016 Nissan Pathfinder.
  • Cyclonic
    Cyclonic Member Posts: 1,232
    I recall in the past there being issues with Safari and the software used here.  My suggestion, stick with Firefox.
    Sterling, VA
  • Vermonster
    Vermonster Member Posts: 80
    I'm having no trouble on safari
  • AldebaranJill
    AldebaranJill Member Posts: 480
    I'm using an iPad and it uses Safari. Maybe clear cache and cookies and make sure you're using the right login credentials.
  • Nomad
    Nomad Member Posts: 7,209
    No safari problem here on any of my three devices - yep, clear cache/cookies and restart safari
  • Verna
    Verna Member Posts: 6,876
    No problems here on Safari. Apparently last night there were probably updates made to the forum software because I had to log into each forum, but that happens every week or so.
  • ColoradoJon
    ColoradoJon Member Posts: 415
    Safari is really strict on login cookies if you run the default preferences.  Go to: Safari Menu -> Preferences.  Click the Privacy Icon.  Check the Always allow radio button under 'Cookies and website data'.  You will be able to login after doing that.
  • Michigan_Mike
    Good information and thanks for taking the time to share it John!
  • Nomad
    For Safari on iPhone/iPads ... Either of the last two coices are fine...Suspect same on desktop...
    When my ipad is slow to load, I end up Clearing History and Website Data on Safari.  It works, but of course I then need to login again...Pxlated, I used your recommended Crop Size app for this!
  • Nomad
    Good boy :-)
    Girl!
  • Nomad
    Ooooops - And I knew that from your sig :-(
  • ericnliz
    ericnliz Member Posts: 4,437
    PXL, At this point, just HOW muddy are your feet anyway? ;) Jump over those puddles! I will have to admit, it IS entertaining though! =)
    PXLated- speaking of signatures - should I be able to view signatures using an ipad/iphone?
  • Verna
    I can see your signature, Sharon, on my iPhone. Watching a BB game on the iPad right now so I can't speak for the iPad right now...
  • Nomad
    Wether you can see sigs or not depends on how you have it set in your profile - Click on your name at top, then edit profile - it's a drop-down under that little profile graphic. There will then be a list of things like signature in the right hand column you can choose/edit.
    OK, I can't see anybody's signatures.  My signature profile has "Hide signatures always" checked and you can see mine???  This is on the PC and ipad - what's up with that?
  • Nomad
    Hide sigs means sigs won't display "for you" not that we can't see yours. Uncheck that and you'll see sigs.
    Well watta ya know!  Gotta change that sig!
  • gilbutler
    gilbutler Member Posts: 169
    I use Safari and frequently have trouble logging into this forum, probably after updates. I found that I can log onto the Little Guy forum, then I'm back in business here.
    Gil Butler, Folsom, CA, 2015 T@B M@XX CS - White with Yellow tim
  • Nomad
    gilbutler - That's kind of strange. Safari has only caused me problems a couple of times. I do keep everything updated.
  • ColoradoJon
    Correct, both of the bottom options are essentially the same.  I use 'always allow' as it is no less secure than the option above it yet has fewest problems with cross URL cookies.
