Can anyone tell me -- better yet -- show me a picture of where the screws are to open to bleed the alde system.  My alde is not heating -- hot water is heating fine -- the glycol "gurgles" when pump is at position #2 -- all the fuses are good -- the battery is full -- I am hoping that the problem is that the system only needs to be bled.  When I turn the propane on, the red light comes on after about 2 minutes.  Any help is appreciated -- Thanks!
Moderator Not: Added from other Alde thread...And altered thread title
My Alde is not giving out heat.  The water heater is working fine.  I have checked all fuses and they are good.  The expansion tank needed some glycol which I poured in --the tank now "gurgles" -- I was told the system needs to be bled.  I took it to an RV dealer in California where I was at the time and they said they bled the system and everything was working -- well, it is NOT working.  I moved the pump gauge from 5 down to 2 and it is gurgling - the glycol obviously is not circulating -- PLEASE if someone has pictures or information as to where the bleed screws are on my 2015 MAX S, I would really appreciate it!  Thanks!
                0 ·
A solid red light means you're out of propane or the Alde isn't getting any. That's what I get at 3:00 am :-( If it's flashing, I think that has to do with electric.
You running on propane, elect, both? What are your sliders set at?
Slider #1 is off - Slider #2 is on propane - Slider #3 is on heat/water
However, 12V DC (either from the battery or the converter) is required to run the Alde's operational circuitry, regardless of whether you are heating with 120V AC or propane. That's why those pesky little glass fuses leave the unit dead in the water when one of them blows!
slide 1 at 3 and 2 at 0, slide 3 on heat and water, knob on 2
red light not on. what did I do wrong?
With these settings you should hear a faint whine from the circulation pump. Try turning the propane up, and you should notice hot exhaust from the Alde vent outside.
If the whole system is silent, and no heat? Try turning the heat temp knob to maximum. Still nothing? Check to ensure you're plugged in and powered up. You can test your 120v by briefly turning the A/C on, and your 12v by turning the lights on inside the camper. All checks out? Check the fuses inside the top cover of the Alde unit. This will require removing the cover under the bench to get to it.
Fuses good? You can try resetting the Alde by disconnecting the power from the T@B and disconnecting the battery for about 5 minutes, and reconnecting.
Still no luck? Either the main control board on your Alde is defective, or the control panel is broken, or the wire connecting the panel and the Alde is broken somewhere.
Let us know how far you get.
2014 T@B CS Maxx
Martha Lake, WA
My comfort zone is a 2 3/4-3 setting.
