Got tired of holding cupboards open with my head so bought these replacement hinges by Amerock Part # BP2811J2314 or if you are in Canada, you can purchase them at Home Hardware Part#2307399. These are a direct replacement, no extra drilling. Works like a charm.
2014 T@B M@XS; 2017 Ford Transit Low Roof, Reg. Wheel Base
1 ·
I'm going to remove the springs now! Thanks.
These are on Amazon
Seattle, WA
from: http://www.tab-rv.com/forum#/discussion/comment/46243
My DM clamshell came with these extra spring loaded hinges on the rear cabinets that pass through to the kitchen. I bought two extras and added them to the front overhead cabinets. Pretty easy install. Similar parts are available at Lowes & Home Depot in my area. ~$2
Just another approach to a solution.
Have fun!
Bob
2017 Max S Outback, 2012 Toyota FJ Cruiser
Their part - Cabinet hinge # 112566
I found this at Lowes with a quick online search. It is what I have seen in my local store. Although not an exact match it is very similar except for the mounting flange on one end and I think it would work.
https://www.lowes.com/pd/Richelieu-1-1-2-in-x-1-1-2-in-Satin-Nickel-Cabinet-Hinge/3576254
Easy, inexpensive, and honestly, the factory should be using these. They're a total drop in replacement.
@Verna = I suggest sending this to factory, these are what should be shipping with new T@B's.
@KBaggins1 Absolutely FANTASTIC FIND!!!!!!
Get rid of your springs! These are way way way way better. I got mine on Amazon.
Amerock BP2811J23-14 1/2-Inch Overlay 2-Way Adjustable Concealed Matrix Blum Hinges, Nickel, 1 pair https://www.amazon.com/dp/B000I24GTQ/ref=cm_sw_r_cp_tai_0j2rybT70AMFF
$8 for a pair!
Seattle, WA
Seattle, WA
Seattle, WA
Where is the Amerock unit made?
2016 Max S Silver & Lt Blue T@B, 2007 Lexus 400h, Rockville & Port Republic, Maryland
Now riding/driving a Thor Vegas, 24.1 around the country
I have one very happy wife!!
Instructions for the Amerock replacement hinges above indicate a 105° opening.
Factory installed struts appear to be slightly less than 90°. See: http://tab-rv.vanillacommunity.com/discussion/4475/2017-t-b-maxs-has-great-upgrades-included
So those two options hold the doors open just fine but in your face.
I wanted the doors to remain open when using the galley, not just for stocking or removing items.
I considered the spring fix since that goes well past 90° if the spring is long enough and positioned correctly.
I ended up using tiny rare earth magnets so the doors snap all the way to the ceiling (cost: $1 plus super glue gel). See: https://tab-rv.vanillacommunity.com/discussion/comment/52584#Comment_52584
A hinge that opens far past 90° and presses the door against the ceiling would be the ideal solution. Until then I'll stick with my magnets.
Strut placement is essential. I have not noticed any issues with a receded opening nor has their been any signs of wear on the wood on the cabinet. If people follow Austin's diagram, stress on the wood should not be an issue.
