Photomom said:We JUST got down below freezing last night. We'll probably go to check on the T@B after a few sustained days of sub freezing weather. We did leave all the faucets and drains open to give any remaining water room to expand.
At the very least, I would suggest opening the drains for the cold water, hot water, and Alde. That would relieve the pressure in the lines and get some of the water out. With a little room for expansion, you might reduce the likelihood of damage in case of an unexpected freeze.DebM11 said:Jumping into this conversation with a similar concern.... only picked up my Tab a month ago and since then I have been recovering from surgery so no time to winterize yet. Only thing we did was open the grey and black and drained off the little water that came out. I opted to plug her in and leave the heat running at minimum. Barring a heavy long freeze (unlikely for Maryland so early in the season) I thought this would protect me for a few weeks. Thoughts?
ScottG said:To that end, I suggest leaving lower cabinets and bathroom door open, and propping open the hatch behind the toilet.
Best hatch prop is a magnet mounted on the wall.
Since you only need to balance the hatch cover on its hinge a stick-on magnet from office supply or craft store should work fine.
I used a 1/4" rare earth magnet mounted with super glue gel as a permanent fix.
With the hatch open you now have a nice little storage area. However, the first mod required is netting (or similar) to fill the gap below the opening 'cause that is a serious black hole where stuff drops down, never to been seen again.
Perfect!ChanW said:Twojgrams, Be sure you opened the toilet flush valve when you winterize, allowing some antifreeze to run into the toilet, or you'll have the problem that I had, a "busted" and "burst" toilet module (Verna had this problem too, if I remember correctly)
Also be sure the black and gray tanks' drain valves have a bit of antifreeze in them, or they'll possibly become "busted", "burst", and "frozen". Open and close the gate valve a few times while the antifreeze is running out the gate valve, to work it into the blade area.
There you go TabberJohn, now a search for froze up and exploded pipes and fittings might get a result for ye. Heh!
@ChanW , my water module wasn't "busted" due to lack of winterizing. The water module broke in early October this year before it got cold.ChanW said:Twojgrams, Be sure you opened the toilet flush valve when you winterize, allowing some antifreeze to run into the toilet, or you'll have the problem that I had, a "busted" and "burst" toilet module (Verna had this problem too, if I remember correctly)
I camped with no problems in AZ ftom Jan 1 to Apr 3, plus camping during the summer. I honestly can't attribute the water module problem on winterizing.
All of my stuff stays inside the trailer during the winter months. Yes, I do travel to Arizona (did it last year) but my cushions have spent the winter inside the trailer in below zero temperatures, etc. and without issues. I do keep my roof vent cracked some ( I have an Aeroflo vent cover too) for ventilation and with cold winter air coming in, it does tend to get dry. If you feel you need to place your cushions in a plastic bag that's your call, but I never had any issues. I'm guessing the large, black plastic contractor style bags would work for that well.geekmama said:What do people do with the bed/seat cushions during the winter? I figured I would take them out, but I wouldn't mind putting them in plastic bags or something and leaving them in the t@b. I'm in New England so it'll get below freezing for a few months.
Has anyone found plastic bags big enough to fit the CS-S cushions or should I just bring them inside?
