Air conditioner mount inside T@B
judymac
judymac Member Posts: 403
While most of you know we are new to camping and to the T@B, she still sits in storage. We are NOT new to banging our heads. I hit that sharp corner on the air conditioner frame/mount and had it not been for my glasses, this gal would have been a mess. Have any of you done alterations on yours? I am thinking of corner protectors often used to keep children safe from those dangers. One corner is sharper than a knife edge.
  • T@Balong
    T@Balong Member Posts: 317
    I cut up a piece of a kid's swimming noodle and glued it to the sharp corner.   And I made it from a bright color so I might see it out of the corner of my eye if I was getting close.
    States Visited Map
  • jkjenn
    jkjenn Member Posts: 6,425
    You could also use a tennis ball.
  • judymac
    edited November 2014
    I think I have a noodle in the garage! Good idea, both of you.
  • Tardisman
    Tardisman Member Posts: 54
    This corner is a safety problem. I had a hard time finding a corner protector that was small and would look good (always try to keep it looking awesome !). I used round adhesive stick on pads for chair legs. Cut them into quarters (pie shaped) and fit them around the 3 sides meeting at the point. It is discrete and has saved us from numerous holes in the head.
    John D.
    2014 TAB M@X S series
  • Mercator
    Mercator Member Posts: 237
    You can find brass corner protectors at Lee Valley
    Ray and Vida Barrick
    (formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
    Toronto ON Canada
  • ChanW
    ChanW Member Posts: 3,171
    I tried rounding it with a file and sandpaper, which pretty much failed, and I continue to dent my head on it.
    A square rubber foot might work, with two sides cut off.
    I'll have to look around.
    Chan - near Buffalo NY
    2014 S Maxx (ie: "320")
