Has anyone done a mod to use the Zamp charging port for a 12 volt cooler? I think I read somewhere that they reverse the polarity but if you had the proper polarity to the cooler would it work or is it set up to only charge the battery? I need just a little more space for the Christmas  holiday and using that port would make it easy for travel.
                2017 Tab Max S (Silver/Black) 2013 Ford Edge
0 ·
Zamp wiring is not is not reversed--it is wired so the positive side is not on the exposed metal side (fewer blown fuses).
