We ran out of water before we got to the campground. when we got in we hooked up to water and put some water in the tank. Now we are traveling again and the water pump makes noise but is not pumping water. What should I check? Does it need to be primed?
                2017 Tab Max S (Silver/Black) 2013 Ford Edge
0 ·
If you don't put enough water in the fresh tank it won't pump - Seems to be somewhat hit/miss so you could try filling it. There has been also mention of having to prime the pump after running the fresh tank dry.
I just drained my fresh and refilled. It seemed to take the pump quite some time before it had the pressure built and automatically shut off. At first it sounded like it was pumping nothing but air, could hardly hear it running. I didn't try the water faucet until the pump quit.
I once had that happen on ours. I think I used the advise from this thread to resolve the issue
http://tab-rv.vanillacommunity.com/discussion/comment/37482/#Comment_37482
Then open and close the sink faucet quickly every so often, while the pump is running, and let the pump run for maybe a half minute longer.
If you don't already know, the filter is under the clear plastic cap on the line heading into the pump. It's a little metal screen that lifts out of two slots that hold it in place. Be careful not to drop it down in the bowels behind the wall!
https://tab-rv.vanillacommunity.com/discussion/comment/37482/#Comment_37482
I would also try running the pump with the faucets open, giving the pump the opportunity to push out the air in the downstream lines. I can understand why keeping them closed and "blipping" the faucets might help pull a prime, but if that isn't working you might as well try the opposite approach!
If you open the fresh water tank drain valve (underneath to left of the door) does your level gauge start dropping from the 94% you mentioned?
Wrap a small towel around the fill hose with the water flow about 1/2 on to be safe. Boom again. Open sink faucet and outside shower valve. Hold hose with towel wrapped around it in the fill pipe so that the vent hole is covered and the hose is sort of sealed to the fill hole. Boom prevention again. I got some air and water splashing back as the tank became pressurized. With the shower head unscrewed and the hose on the ground the water began to flow. Stopped filling and closed the sink faucet and the outside shower and everything was back to normal.
If you do not have a pressure hose available, blocking the vent hole and a short vinyl tube that is higher than the pump might accomplish the same thing. Just need to find a vinyl hose that fits the fill hole tightly.
