Just got our new Ford Transit to replace our 2002 Suburban
Greatly appreciate your advice. Please see the photo.
As the trailer nose up slightly at tongue, is it ok? Some advised need be level but most said ok.
What is the right way? May you also share your photos?
TIA
Not sure I should get a flat extension (which only comes a 3 balls that I believe it will be level at 13" and adding the ball will probably get to 16" at ball top.
What should I do to be right ? Thanks very much.
You need a 2" ball. Are you sure you are on level ground? The picture might be skewed or distorted.
Looking at the hitch you have, you can turn it upside down and re-torque the ball (if it's not welded on) and from what I can see, you get about a 2" drop. That should be enough.
Sway is mostly a product of tongue weight, but it can also occur if you are towing with the coupler on the trailer quite high - an inch off either way isn't a big deal, but lower is better than higher. Remember, you're going to have things in your vehicle that load it down as well as your trailer with items in it (and a min 48# battery and 20" propane tank).
Right now, I'd go find a gas station that has a slight rise in their drive into the pumps and listen to hear if the back tire underneath scrapes. If it does, you'll need to lower that hitch height - or consider moving the spare to the tongue and forget about changing hitches as that will add 40# to the tongue weight.
Tim & Jill
Tim & Jill
May be this hitch will work as it is flat (level w TV at 13 bottom and with ball top close to 16
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
2008 DM T@DA — Towed by 2014 Dodge Durango — Full time since 6/29/17
"Travels With The Tiny"
It's kindof hard to see but that piece of plexiglass has holes that correspond with the bolts put into the A/C vent grid. I remove the wingnuts, put the plexiglass over the bolts and tighten down the wingnuts.
MOUSE-KE-T@B
Harvest, AL
Alan & Patty
Southern Az
Very much like to know what hitch (flat, drop, or rise) to connect the two to keep level. And where do you have your spare tire?
Hold a ruler up to your photo with edge under your Transit wheels and you'll see that line doesn't match the T@B wheel.
My suggestion would be to find a level spot and check again.
Also consider loading your TV and T@B with what you normally expect to carry. Or some concrete blocks.
If necessary flip the ball as @elgolfo suggested or go with a no-rise receiver.
An adjustable hitch is useful if you have multiple trailers of various heights and tongue weights to deal with.
A TV with tow package isn't going to vary much in height especially hooked up to a T@B.
