I'm planning on completely removing the exterior plastic edge trim from the upper corners of our Outback and leave the roof-wall joints exposed. There's just too many cracks in the plastic to repair or replace. Does anyone have photos of what the joint looks like under the plastic? How ugly is it going to be? Are there waterproof issues to deal with? I'm just getting tired of dealing with the cracks.
Thanks for the advice in advance.
0 ·
Sterling, VA
2016 Jeep Cherokee & 2017 T@B Outback
I haven't checked for cracks in the other plastic parts. It's at a local rv dealer having the wheels greased.
What was your weather like this winter?
Even better, it is easily solvent bonded with acetone or MEK (thin), or ABS pipe cement (viscous) Some "scraps" can be dissolved in the solvent and used as a glue if gaps need to be filled. Thin syringes (insulin type) can be used as capillary applicators, ideal for thin cracks.
Superglue can be used too, but is brittle.
These articles helps to understand solvent welding and re-surfacing.
https://depts.washington.edu/open3dp/2012/05/abs-solvents-4-good-ideas/
https://forum.lulzbot.com/viewtopic.php?t=1322
If trim is NOT ABS, ignore all of the above and think "oh those newbs, they need so much help, while shaking your head, and muttering tsk, tsk."
Goes where it's towed to by 2017 Subaru Outback
I did speak to the factory just over a week ago and was told that the seal does nothing more than provide some stability to the trim and has no sealing application to keep water out, etc. so not top worry if it appears to have a small gap, etc.
Comments???
Yikes. Should be a warranty fix.
