Cleaning the Blinds
Nomad
Nomad Member Posts: 7,209
Has anyone figured out a way to clean the blinds - cleaner/method? They're so flexible :-)
Was thinking of filling the window behind with a folded up blanket or something.
  • Verna
    Verna Member Posts: 6,876
    Chloride wipes don't work for squashed bugs on the blinds. That was all I tried yesterday.
  • Nomad
    Tried the folded up towel between the window and blind and they are still a bugger to try to clead :-(
    Any suggestions?
  • Verna
    Q-tips and alcohol from the outside with the window up? Or maybe get a foam brush with alcohol--that would cover more area quicker.
  • Nomad
    Both sides actually need it - The problem is they're so flimsy it's hard to get and scrubbing action or pressure on them.
  • db_cooper
    db_cooper Member Posts: 749
    Drive real fast with the windows up and the blinds down???:)
  • Nomad
    Tried that first :-)
  • Verna
    Two people with foam brushes on each side
  • Nomad
    Only got one -> When ya showing up Verna? :-)
  • Homebodyatheart
    What about some kind of pump sprayer thingy, like the ones Verna and Jenn use for dishes. You could spray them from the inside, pushing them off that way? Other more drastic option is to buy a new T@B...:-)
  • Verna
    Next January......
  • jkjenn
    jkjenn Member Posts: 6,425
    I have successfully used them on bugs - it must depend on the type of bug. :)
  • ericnliz
    ericnliz Member Posts: 4,437
    PXL, You could always find a Southwest bug collector to help 'ya. I'm sure you have every kind, form & fashion by now.  =)
