Change color on Max s
Any idea what it would cost to change the color on a Tab max s.  Just the highlight colors from say blue to black.  Is this a hard thing to do and does it even make sense?
  • Tommy
    Tommy Member Posts: 175
    I priced out a trim color change from the store and it came in a little under $1800 if I remember right.
    Go to the TearDrop Shop at www.tab-rv.com under Trailer Parts.  If you replaced all the trim work it runs $2130.  If you are just going from blue to black, probably a lot less expensive to paint it yourself.
  • Tina111111
    Tina111111 Member Posts: 1
    What kind of paint would be best to repaint them yourself?
  • jkjenn
    jkjenn Member Posts: 6,425
    If you want to do it, call Elsie at the factory. You might save some money.
