I picked up my T@B Sofitel last week - my TV is a 2006 Lexus RX 330. I had the brake controller installed at the RV dealership and they flew through the instructions so I am not quite sure how it should feel.
I have years of experience towing a 21' Bayliner behind a 2000 Tahoe. This feels VERY different. And not in a good way.
Here's my question: Is it possible that the brake controller is causing "drag" on my suv while driving? Braking is great, towing "feels" like I am dragging, not rolling.
Am I imagining this?
                0 ·
Here's something you can try. Drive it on a long straight road, or the freeway, using as little braking as possible. For 5 miles let's say. Then, pull into a gas station, and immediately check the temperature of the black brake drums. You can stick your fingers between the spokes of the T@Bs wheels to reach them. They should be either cold or lukewarm. If they're hot, or one side is hot and the other cold, the brakes need to be adjusted ASAP.
The T@B is very susceptible to wind drag, so keep this in mind if it feels like pulling back.
2014 T@B CS Maxx
Martha Lake, WA
So you're saying if the brakes feel hot, then they are indeed engaged and need adjusting? Brakes can be engaged even if my foot is not on the brake pedal? This is exactly what I suspect based on how it "feels" under tow.
If they feel hot, is this something the RV dealership needs to adjust? Or can any car dealership tackle this?
Thank you for weighing in on this!
When we test-pulled a T@B before we bought ours, one side of the brakes were almost smoking after a couple miles of towing! Now given they were the hydraulic type, the dealer apologized and said they hadn't adjusted them yet as part of their vehicle prep before sale. Not to say this is what's happening of course.
2014 T@B CS Maxx
Martha Lake, WA
Admittedly I'm no brake expert, so I'm happy to hear of others experiences or opinions. I do agree the brake drum/wheel/hub should not be hot to touch after driving normally.
