We've towed our T@B with a 2012 3.6 Subaru Outback for two years, mostly in the mountainless midwest. I wouldn't call the Outback overpowered for the task but it's been a serviceable TV that didn't seem to strain and never overheated. This week, on our first trip of the season (on flat-as-a-pancake I-29, no less), our transmission went out soon after we started.
We've been loyal to Subaru for many years and have never had any issue beyond routine maintenance so this surprised us, especially in a car with about 50k miles. Lots of people tow with 3.6 Outbacks--has anyone blown their transmission or is it a fluke?
And the big question: once the transmission is replaced, do we continue to tow with the Outback or is it prudent to trade for a TV with a little more juice?
Thanks, forum!
Doug
Des Moines Iowa
2016 S Max Sofitel
0 ·
And, yes, I'm really sorry that your 50,000 mile car had transmission trouble. That is far too soon.
We do not tow with this vehicle. In the meantime we found that the engine was using oil. The dealer had always changed the oil every 5000 miles, even though the recommendation is 10000. It is of note that if the dealer always changes the oil and the owner does not check the oil, no one does. There is a documented problem with burning oil as well. At any rate my husband is now driving a Toyota. We are so disappointed in Subaru service, in particular the service department's lack of expertise, we are not likely to buy another Subaru.
2016 CS S, 2008 Toyota Tacoma
Somerset, VA
I'm curious to see how these heavier car based unibody SUV's like the Highlander hold up to towing. I'm not sure the transmissions are beefed up enough and we've seen the pictures of the Ford Escape hitch failure since there was no frame to bolt to. Very few truck frame SUV's to choose from these days. Might consider a 4Runner before they disappear.
2022 Ford F350 Tremor | 2022 Cirrus 620
Working in the Automotive industry for 40 years I can say that adding an additional AIR/OIL hayden style trans cooler to the front is MANDATORY if towing. Servicing the transmission and differential fluids every 15k for tow vehicles is recommended by most manufacturers.
Off topic: Brake fluid draws moisture. Companies that bottle it say to replace it in a vehicle every 3-4 years, do we?
Those Jatco automatics found in older Subarus and still in the 6 cylinder models are TOUGH cookies. You'll get a dash alarm if the temp gets high enough to cause any damage.
As for manual transmissions, believe me you can overheat them too! I almost cooked my Jettas when towing it at 65 up a 6% grade for 10 miles. It has plenty of power to keep the speed, but when the engine reached 230F at the pass summit (just beginning to move the needle past middle, temp reported by ScanGauge) I figured it probably wasn't the smartest thing I ever did. On the next routine transmission oil change, the oil sample report was cooked oil and a LOT of iron in it. It survived, but towing duties are since handed over to the SUV.
2014 T@B CS Maxx
Martha Lake, WA
IMHO you are asking for trouble hauling a T@B with vehicles that are borderline (e.g., load rating that includes trailer, gear, vehicle occupants, etc.) as irregardless of the fact you can get the trailer rolling down the highway, things do heat up over time, heat takes a toll on materials and components, oil breaks down and you end up being stranded in remote areas and it costs a lot of money. This is why I purchased my Silverado as it handles the load easily, it came with a tow package and can handle the mountain grades with ease.
The T@B units are not aerodynamic and they do create drag, which creates pressure and obviously heat things up while traveling. I'm not one to roll the dice and believe that anything you tow behind any vehicle should be towed with a unit that meets or exceeds the load being towed. Just my opinion as I've towed many large loads (e g, poles, transformers, large padmount transformers, large digging/trenching/pole setting units, swamp vehicles, etc.) and equipment having spent 40 years in the utility industry here in Michigan and have seen many events/accidents happen and know that a load will easily push a vehicle down the road too when trying to brake and result in some catastrophic events. Things change suddenly and accidents/events happen during inclement weather conditions, poor visibility, slippery/wet roads, when people suddenly turn in front of you, when they are texting & driving, when a tire blows, etc. and these trailers must be controlled.
You get my drift!
@Hans111, I am sorry to hear about your Subaru. I'd have to agree 50,000 miles seems like a warranty issue unless it was absolutely abused on a regular basis. Good luck with your decision for either replacing the trans., or a new tow vehicle. Personally, I'd go with something with a higher tow rating capacity, but that's just my humble opinion.
Will your Subaru tow for hundreds of thousands of miles without repair. No! definitely not.
You can buy a large pickup truck for $5,000 more. Then you can pay the gas and insurance of owning that pickup truck.
--or--
You can use the Subie and after five years you can replace the trans for $1500 or $2500.
With all that said, the OP needing to replace the trans after 50K is a bit too soon. Stuff happens.
.....and the old saying " you have to pay to play".
Every company produces a bad apple from time to time, even Lexus and Toyota.
Last I heard was Subaru kept the geared transmission for the H6 exclusively and equipped all other models with the CVTs. Perhaps that's changed now?
2014 T@B CS Maxx
Martha Lake, WA
Agree the H6 isn't borderline, but you do have to expect accelerated wear compared to towing with a truck. I think they went to the CVT in the H6 with the current generation. Haven't been paying too close of attention as our 2001 Outback only has 210,000 miles and everything works as new, so no new car in the plans right now. It still has the coldest AC I've ever had in a car, and it's never been recharged.
Anyway, I'm also glad Subaru postponed their plans, because the first couple years models sold in Europe and Australia had problems with the crankshaft cracking and splitting at low mileages. I think they've since fixed this now, and with the CAFE standards coming quickly, you'll be seeing a lot more diesels on the road.
Mazda is releasing their diesel CX5 later this year, for one.
2014 T@B CS Maxx
Martha Lake, WA
The Subaru dealer has had the car going on four weeks and still can't get it to work after two new transmissions. Their technicians are troubleshooting with Subaru engineers but no luck yet.
The transmission trouble may be a fluke--longtime Subaru fans here--but we've already traded for a TV with more power. I'll miss the Outback, though.
Des Moines Iowa
2016 S Max Sofitel
tv 2010 Lexus RX350 Matador red
horsepower or torque. Owners who have had the "fix" don't seem to have many complaints.
http://jalopnik.com/volkswagen-tdi-owners-seem-mostly-happy-about-their-die-1791432942
So, I'm hoping things will work out.
The fix isn't ready for us (V6 TDI) yet.
2014 T@B CS Maxx
Martha Lake, WA
