What do you do with your Lagun Table when the bed is setup
BirdieJane
BirdieJane Member Posts: 237
We find dealing with the Lagun Table, while setting up the bed an UN-enjoyable routine, What do others do to make it easier?  Where do you put your table when the bed is setup?
aka BirdieJane towed by Quinn
  • hymie
    hymie Member Posts: 150
    I replaced our tabletop with a solid piece of wood and cut it the right length to replace some of the bed slats at night if we want.
    James & Jacquie     Almonte, Ontario
    2016 Jeep Cherokee & 2017 T@B Outback
  • Vikings
    Vikings Member Posts: 147
    Our Lagun table top also does double duty as a bed "slat."  Fills up about half the space and I made two more half size matching "slats" to fill remaining space.  Half size allowed us to stow them away easily...see photo.
    It is still a bit of a process to remove from pedestal, mount pedestal on bottom of table, and put in place for bed...but better and lighter than table that came with ours in 2016.
    Kim & Mary Kay,  2016 CS-S,  Spokane, WA
    Map of Provinces I Visited
  • dragonsdofly
    edited May 2017
    Ours is a 2017 sofitel max s. The table is usually outside ready to use or has a microwave on it while we are camped. As a post script, ours came with the outside mount and a full set of bed slats.
    Depending on which table top you have, it may fit in the top of the front passenger side bench.  Someone had a picture here.  It rested nicely on the rim that supports the lid.
    The outside mount really does get it out of the way.  You can use a Walmart table inside, too.
  • Rolltide82
    Rolltide82 Member Posts: 89
    My table is in the shed.   Never use it....got tired of it getting in the way.....plus I don't spend time in the t@b unless I'm sleeping.
  • dsatwork
    dsatwork Member Posts: 744
    We leave it on a lagun bracket mounted outside most of the time with our convection toaster oven when camping. But it fits perfectly in the top of the passenger side wheel well compartment.
