Hanging things on the walls
I am a complete newbie and just got my first T@B. I am sprucing up the interior and want to hang some things on the wall. Is it like hanging something on a regular wall? Do I use screws, nails? Silly question, I know, but any help is welcome. Thanks!
  • BirdieJane
    BirdieJane Member Posts: 237
    So the walls if at all possible should be left as the are, meaning don't poke holes in them. They are basically thin aluminum sandwiched over foam. Command strips and heavy duty Velcro works well. Give it a try.
    aka BirdieJane towed by Quinn
  • jskreader
    jskreader Member Posts: 3
    I didn't know what they were made of but I suspected it wasn't made for heavy construction! Thank you for your help. :-)
    pthomas745 Administrator, Moderator Posts: 4,668
  • TabberJohn
    TabberJohn Member Posts: 588
    edited May 2017
    Actually the aluminum is in the struts and exterior roof only:
    http://tab-rv.vanillaforums.com/discussion/comment/67801#Comment_67801
    Scroll down on that post and you'll see some pictures taken during construction.
    The outside walls are a fiberglass mix (Alufiber) and the roof is a thin aluminum.
  • Verna
    Verna Member Posts: 6,876
    One model, and one model only, has aluminum on the outside of the walls, in addition to the roof,  and that is the Sofitel.
  • jskreader
    Thanks to all of you! The last thing I want to do is mess up this gorgeous teardrop so I heard you loud and clear. :-)
  • Restless_Native
    Restless_Native Member Posts: 117
    Welcome to the T@B family! Just an FYI - I live in S. Florida so my camper is in the heat full time. The command strips work great. Wipe the wall with a little alcohol and let dry before adhering. And don't use the new clear sticky strips. They don't hold up to the heat. The others work wonderfully!
    Amanda Evans 2026 360 CS Black Canyon lithium package. Ford F-150 tow vehicle
