Your unit is under warranty and a call to either the dealer or factory will be able to remedy your problem. As noted by the other members, it might only require a slight re-alignment and adjustment of the door.Tabu said:We have a 2015 T@B S Max and I noticed there is no way to secure the shower door from the inside. It also seems a little sloppy closing which might cause water to go outside the shower should we ever use it. . Any thoughts or ideas.
