T@B S Max shower door closure.
We have a 2015 T@B S Max and I noticed there is no way to secure the shower door from the inside. It also seems a little sloppy closing which might cause water to go outside the shower should we ever use it. . Any thoughts or ideas.
Tabu - Rita & Phil and Doli who is a 2015 silver frost/blue S Max being towed by a 2013 Subaru Outback 3.6l
  • jkjenn
    jkjenn Posts: 6,424
    edited January 2015
    It sounds like it needs to be adjusted. Mine closes snugly.
  • Rad
    Rad Posts: 516
    Mine is like Jenn's, closes very snugly, almost too snug
  • ChanW
    ChanW Posts: 3,165
    Our 2014 closes tight with a magnetic strip that holds it shut.
    Doesn't have any problems with leakage when showering.
  • Nomad
    Nomad Posts: 7,209
    My 2015 is also tight.
  • mawebb
    mawebb Posts: 257
    My 2015 closes very secure with the magnetic strip that runs the full length of the door (top to bottom). It sounds like either something is missing or there is a considerable misalignment. Tabu can you post any close up photos from the inside with the door closed?
    Your unit is under warranty and a call to either the dealer or factory will be able to remedy your problem.   As noted by the other members, it might only require a slight re-alignment and adjustment of the door.
