I was checking out the driver side bench seat on my 2015 S and could not help wondering if there was not a way to gain some storage in this location. There are power cables, water pipes and the converter consuming a fair bit of space. I was thinking about building a rasied shelf that can be removed. It would sit above all of the pipes and wiring and could be easily removed for access for servicing. It might only give 6 to 8 inches of depth, but that would be better than none. If I build something I will certainly post up some photos. Any comments or suggestions would be appreciated. There is also room around the ALDE, but I am not going to pursue that at this time.
1 ·
We found several units that fit in the space nicely and used them for the top half the space while leaving the Alde cables and conduit underneath undisturbed and uncrowded.
In in terms of the converter heat, I will check it out further, but I don't recall any vents inside. If there are, I will ensure enough air flow and can provide a mesh in the area above the converter to allow the heat out.
Here are some interesting concepts that others have utilized in varying degress:
Martin, I feel your pain― all of those little things add up!
http://tab-rv.vanillacommunity.com/discussion/4037/under-seat-storage-added-wood-platform/
