I finished this project this weekend (with help from my brother-in-law). I really like this Maxxfan Deluxe and I can't wait to get it out and use at a campground. Thanks for all of the great threads on this subject. There is one thing I do want to mention that others may or may not have encountered. I have a 2017 T@b and I discovered when I was putting screws into the mounting flange that I was hitting the aluminum support around the fan opening and buckling the surface of the T@b. We ended up using self-tapping #8x1" stainless screws and everything worked perfectly. I guess we could also have pre-drilled pilot holes for the screws, but I did not want to take the chance of going in too far. Anyway everything worked out fine and I have a great new vent fan! Dave
It would be easy enough to remove the wood frame and I would prefer to do so. The wood frame drops the headroom down 3/4".
Love this fan.
Sterling, VA
Also to be safe, I contacted Creed at NuCamp to ensure nothing special had to be done, and he said no. I was a little concerned about the stated minimum roof thickness, but no modification was required. We did not need to use any shims.
I had a mobile RV guy come to my house to install it for me. His hourly rate is the same as brick and mortar shops, but he also charges a house call fee. Well worth it for me as he was done in less than two hours and I could watch and not have to leave the trailer somewhere.
He unscrewed the four FF screws inside, then used a knife to cut the caulking up top, and pried off the fan and cleaned off residue on the trailer. He used butyl tape (like putty) to adhere the flange to the trailer. He predrilled the four holes for the screws as was suggested and installed the top. He used a thick tape called Eternabond rather than the goopy, messy Dicor caulking stuff to seal. He said it holds real well for years. He then cut the inside frame to the correct depth and it was done.
As others have noted, this fan is wonderful! It's so quiet I had to ask the guy if it was on. Now I have a fan that uses much less energy than the Fantastic Fan three speed, has a rain cover, looks great, all speeds work, and it's quiet, did I say that already?! Oh happy day!!
Sold 2023 Tab 400
Sold 2018 T@B 320S
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium
https://www.campingworld.com/maxxfan-deluxe-remote-control-rv-ventilator-system-smoke-lid-48934.html?CAWELAID=120071740000168269&gclid=Cj0KCQjw4-XlBRDuARIsAK96p3Bo3YIG9eTxkeJn8RJsQY-kOdsZoDEMDT_vtXE4i0W3enlmTMGTuIoaAkEGEALw_wcB
Sold 2023 Tab 400
Sold 2018 T@B 320S
