Lagun Dinette
Frost772
Member Posts: 11
ok, I just purchase a 2018 CS-S. During my orientation we didn't go over the table. I can't figure how to lower the tableto make the bed. I've only attempted 2 times but if someone got give me some instructions, that would be great. Does it come off the mounted bracket? Maybe that's the part I'm missing. Help!!! Lol
2017 T@B CS-S silver with silver trim ("T@Boo') pulled by a 2015 Subaru Outback (6 cyl)
AT GA-ME 2000
You need to remove the top by loosening the ratchet handle directly under the table, then remove the cross bar and vertical bars by loosening the lowest ratchet handle.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Ratchet...ahhhhh. I'll get it a try. Thanks so much.
AT GA-ME 2000
Love our CS-S! Our model doesn't have the Lagun table. Sorry can't help...
Yeah, the trick is the ratchet handles. Crank, push the button in & rotate back to start position, crank again.
LOL thanks for the tip on taking the table top off, SAM. That'll make it easier. I've just been lifting the whole thing off. It's heavy.
2017 CS-S Max (Silver & Yellow), TV 2019 Ram 1500
Camping under the Big Sky -
Yes, much easier to deal with the tabletop separately. If you have the standard gray rectangle top, you may be able to store it under one of the passenger side benches, too. Someone here had a pic of that.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
