Water valve replacement for toilet
Anyone know where to order a water valve? The toilet is a Thetford (2015 T@B).  model number of toilet is 31646. On-line seems to have other model numbers. any input appreciated. Manufacturer is also having difficulty finding this part. photos might help
Barbara in Durango... T@B Max S 2015...Red & White... pull with 2016 Toyota Forerunner
  • Verna
    Verna Member Posts: 6,876
    Call nüCamp, they will have the parts or can get them quickly. Some parts have a two year parts warranty on them.  Search for a thread by me about a part that needed to be replaced last fall 2016.
  • luvmytab
    luvmytab Member Posts: 66
    thanks Verna, I did call nucamp and spoke to Elsie and she and a fellow worker did not have a clue even though I had the model number and name. I sent her the photos and hopefully tomorrow morn we will get the part ordered. I will check the warranty as you suggest.
  • Verna
    Marvin was the one who knew what was wrong and he knew which part was needed. He now works in Warranty, but maybe Elsie can talk to him.
  • ChanW
    ChanW Member Posts: 3,165
    edited June 2017
    I bought one for ours on Amazon. Ours is a 2014 (late 2013)
    Cheap, $20. Easy replacement. (Honest, Verna!  =)  )
    Here's the link:
    https://www.amazon.com/Thetford-31705-Aqua-Magic-Toilet-Assembly/dp/B002UC1AYQ
  • luvmytab
    thank you, chanw! got it ordered and arriving Friday. BTW, i love your little tabl do ya.
  • luvmytab
    and thank you for your info, verna!
  • luvmytab
    ok, part is in. the mobile RV repairman charged me $150 to pull the toilet and identify the problem as the water valve.(he also helped up a bit(10-15 min) with the winterizing  Anyone install this themselves? My son has installed toilets in my home and his. Would love any input, before i call back the mobile guy.
  • Mr_Mrs_Gnome
    Mr_Mrs_Gnome Member Posts: 241
    @luvmytab, where did you find the model number? I just got my 2017 Outback out of storage and the black fitting popped off when I turned on the pump.
  • Mr_Mrs_Gnome
    @ChanW, did you pull the toilet to replace or have it done?
  • ChanW
    edited April 2018
    Thanks Barbara
    @luvmytab, yes I installed it. It was a breeze. The (rubber) seal for the toilet to the black tank was included in the 'kit', so no worries about cleaning up wax.
    @Mr_Mrs_Gnome, isn't the above link to the Amazon part correct anymore? here:
  • Mr_Mrs_Gnome
    @ChanW, the link is fine. I was just wondering how to pull/reinstall the commode and identify if I have the same model as Barbara.
  • dragonsdofly
    @Mr_Mrs_Gnome, DH pulled our toilet and replaced our valve last year, June,  2017. He says very good directions are included with the valve. The toilet reinstall is only  2 bolts. The commode is seated on a foam gasket, not wax like in the home. Said foam gasket comes with the valve replacement so you will be good to go. Tip: someone with long arms makes it easier!
  • Mr_Mrs_Gnome
    Thanks @dragonsdofly! Sadly I’m 5’3”. Gnomies don’t have very long arms. I might be able to borrow an elf, though!
  • dragonsdofly
    edited April 2018
    @Mr_Mrs_Gnome, then you probably have the manueverability advantage in the lieu my DH at 6', 220 lbs didn't. But all in all, sounds like you have a plan!
  • jkjenn
    jkjenn Member Posts: 6,424
    What both @Mr_Mrs_Gnome lack in height they more than compensate for in charm.  =)
  • jkjenn
    Great write-up, Fergie.
  • Fergie
    Fergie Member Posts: 143
    Thanks, jkjenn!
