Adding a map to my posts
LaurieOregonGal
Member Posts: 12
OK, you all, how are you adding that cute lil' map showing the states you've traveled. I'm wanting to add that to mine.
Thx! Laurie
Thx! Laurie
hi Laurie, I found mine at this site
http://visitedstatesmap.com/Jim & Nadine 2015 T@b Max S pulled by 2016 KIA Sorento - East Wenatchee, Wa
Thanks! I'll give it a try!j_ntabowners said:hi Laurie, I found mine at this site
Laurie -
@j_ntabowners...thanks! I've been wondering how to add this
Living in our Airstream, traveling in our 2017 T@B Basic S
Married to Dave-aka, ds@work -
you are welcome
Thanks!Amanda, Ft. Myers, FL Ag@tha 2017 T@B CS-S , TV: 2013 Chevy Equinoz LTZ
When I try to add mine I get a pop up that says "no images allowed" . When I tried to add it as a link it said the same. Perhaps since I a newbie..?
@Dptrit- We have the same thing happen every time we try! Have put out messages to several people who have it on their signature, and no one has been able to help. @Verna - any ideas? The only thing I wonder is if those people had it before the upgrade for the forum. @LaurieOregonGal- thanks for asking!2016 T@B CS-S silver with white trim and WSU themed
Same here...images not allowed.
As @2Cougs noted this appears to be a limitation of the new forum format.
Perhaps a moderator or nüCamp IT can enable the function to allow images on signatures.
Until then you'll need to go analog (ex. AK-MT-NV-CA-UT).
2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow) -
If I try to update my nights out/mileage (or anything), I'll loose my map.
UPDATE (Sept): Image limitation seems to be gone
Someone on this forum gave me a link to do a similar map. I followed the link and it worked but along with it I picked up an annoying pest that now shows up every time I open my browser. It's called online map finder. If you get it and I hope you don't, expect to have to have a professional get rid of it for you.
Earl & Sue | Central NY |
2017 T@B 320S | TV: Chevy Silverado -
Oh no! We do ours where you mark the states, save the image, then attach the new image. So sorry what you are going thru!2016 T@B CS-S silver with white trim and WSU themed
@2Cougs Which URL did you use to create and modify your map?John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner -
Visitedstatesmap.com
it won't let me copy and paste the URL, so I just copy the image, resize it, and load it into my signature like any other pic.
There may be a better way, but that's what we do.2016 T@B CS-S silver with white trim and WSU themed
@2Cougs thanks!John, Judi, Guinness & OD in PDX
I went to the website and made my map. When I tried to insert the map into my signature, I used the URL for my picture but it didn't work. I think that I'm missing something.
Gail & John
I tried copying it, saved in my photos, selected it and tried to attach it in my sig, and bupkis! You're in good company if I may say so myself.John, Judi, Guinness & OD in PDX
I have never been able to copy and paste in the URL... I actually save the image to my computer. Then I have to resize it. Then I use the symbol just above this box that allows you to select a photo on your computer to upload.2016 T@B CS-S silver with white trim and WSU themed
I'll have to tear myself away from the iPad and try using the desktop.John, Judi, Guinness & OD in PDX
Yes! I can't do it on my iPad... Let me know if it works.2016 T@B CS-S silver with white trim and WSU themed
Right now we only have one lonely little state showing... Wonder where we live?Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI -
Next spring head our direction... Or maybe we could meet you part way! You need to get your map filled in
TerryV6 said:@j_ntabowners...thanks!
How did you do it? I've tried pasting the link to the URL but it showed up as the link, not the image.Gail & John
Well, I got that my first try too. Then I went to the site and copied my map from the screen as a jpg. I went to my edit screen and had the cursor below my text. Now, choose the rectangle with a pic from the selections above the text box. It will say Insert an image. Find your saved image and then save your edit. Tada! Hopefully you will have more states than we do. Just to be clear, I am only listing states we have been to with our T@bby, not where we have camped. We'd have a lot more...
T@bbey Road
Appleton, WI -
It worked! Thanks so much! We're one staters as well, and we're in a pretty big state so it may be awhile before we add any.
Gail & John
You are welcome..Terry & Jody... 2025 Honda Ridgeline RTL
T@bbey Road
Appleton, WI -
Well, who knows what changed, but today, following Alan's directions, I finally managed the map. The only difference being I selected the smallest sized map on the site, and I was able to copy the URL into my signature. No resizing needed on this poor iPad and no copy and pasting required. In case you haven't tried it lately on your iPad @2Cougs, you might try again when it's time to add a state. Thanks @WillieontheRoad and all of you who've helped us technologically impaired members.
JudiJohn, Judi, Guinness & OD in PDX
@Twojgrams - good to know! Once the snow and ice melts, and we head on the road again, we will try it!2016 T@B CS-S silver with white trim and WSU themed
For any of us who might be struggling with technology...I added my map on a home computer. Don't know how I would do it on our IBook.
The map site Judi recommends works fine. No need to find another site.
https://visitedstatesmap.com/
I would add all the states you plan to visit in let's say the next three months. Reason...You will need to do these steps all over again when you need to add more states.
Copy the map with states selected as a small URL as Judi suggested.
Then go to your profile page and select 'edit profile'.
Select 'signature settings', and find the symbol that looks like a little landscape.
This will have a drop down menu. Select 'image URL' and paste your copied URL from the map site.
Hint...shortcut for copy on PC's is C'NTRL c. Mac shortcut is command c.
shortcut for paste on PC's is CNTRL v. MAC shortcut is command v.
This shortcut will save you much time when you are adding photos, text or images, etc.
Good luck,
Alan
2018 T@B 400 Jeep GC
Alan & Joan Fisher
Austin, TX -
@WillieontheRoad - I misspoke above, I should have said no copy and pasting of the Map! Itself Is needed. My iPad photo library is full of these maps. And I realized that in the past, I was trying to copy and paste the URL from the web address site at the top of the screen, like I always do when copying a URL, while ignoring the actual field on the page which clearly states Copy and Paste Image URL. Too impatient, too much chatter on the page. I can hear multitudinous teachers' voices in my head- Read the instructions at the top of the test carefully-All right students, you may begin. Sheesh.John, Judi, Guinness & OD in PDX
- 916 Introductions
- 73 Teardrop Groups & Links
